When the WEMA tank monitor is pressed to either waste or water the gauge does not register at all. Does anyone know what the proper sending units are for the waste & water tank
Thanks in advance
The following 1 user Likes OurHighLife's post:1 user Likes OurHighLife's post bsause (05-23-2020)
Author's Statistic:
Threads: 14
Likes Given: 1
Home Port: Kings Park, NY
Threads: 14
Likes Given: 1
Are you sure the sensors are bad? I've had similar problems with both readings. I found many times I needed tap the gauge while holding the appropriate button (fresh water or waste level)... Another thing I did was to pull the sender for the waste tank and found it clean but it doesn't reach the bottom of the tank...I've included a diagram showing the depth my sender goes down in the waste tank so when the tank is less than 4" full it shows empty. M2C.
The following 1 user Likes ReelMagic's post:1 user Likes ReelMagic's post bsause (05-23-2020)
