Power Helm Seat
Hey all! New owner of a ‘99 4000 here. We’re coming from a 1968 Chris Craft, so this is like moving into a space station for us. I’ve got one question at this point...the power helm seat isn’t working. The previous owner says it was working at the end of last season (boat has sat since recommissioning). I see a fuse on the panel at the helm.  If it’s just a blown fuse, do I remove that rubber boot for the one labeled for the seat and replace it, or is there something else I’m missing??
Sorry if this is a super-basic question and I’m missing something totally obvious.
[-] The following 1 user Likes MC1600's post:
bsause (08-09-2020)
Yes check that first !!
So it just screws out? I pressed on the boot and the button wasn’t popped out or anything.
That is a resetable breaker. If it is tripped it will be sticking out. If sticking out push it back in and see if the seat works. If it isn't sticking out then its not tripped and there is probably a connection issue somewhere.
First make sure you have power at the breaker and start tracing it from there. Power should flow from the breaker to the switch to the seat motor. If it is getting all the way to the seat motor, then it needs replaced.
The rails on the travel mechanism are subject to corrosion. If your problem turns out not to be electrical, look to see if excessive corrosion is causing the motion to bind up. This is especially a problem if the seat has not been regularly repositioned.
  Removing Wall Panel on other side of helm on Sovran 3500 no shocks 1 966 02-15-2026, 03:38 PM
  [Tiara Open] 2007 Tiara Cockpit Seat and bolster mounting brackets Roweje 0 631 06-28-2025, 12:35 PM
Last Post: Roweje
  Reinstalling power vent in windshield. 1993 3100 open barefoot446 2 1,093 06-15-2025, 08:09 PM
Last Post: penneyma
  [Tiara Sovran] Shore Power Cable Replacement wwaseleski1953 2 1,166 06-12-2025, 07:50 AM
  [Tiara Open] Electrical Issue: Some helm switches not working twilson0929 3 1,414 04-24-2025, 09:03 AM
Power Helm Seat00
