Getting into tiaras
Hi all, my wife and I are looking for a 2900 open. We think we have found the right boat but it’s lacking a few things on our punch list. One of them being heat/ac. Can anyone provide an idea as to what it would take to install a factory system on this boat? Even pointing me in the right direction for resources would be great. Things such as what brand, size and what would be involved is super appreciated. It’s a model year 2000. Thanks in advance!
[-] The following 1 user Likes Jimnic's post:
bsause (03-07-2021)
Dometic system for that boat is gonna run @ 3800$ at least without labor for install.
Not something I recommend you do on your own. Worth the money to hire a good ac / refrigeration co.
Just did two new on my 47 and I have 4 units.
Woof! That’s a big number. What size unit is that for?
I had Marine Specialists of Ronkonoma NY ([Only registered and activated users can see links Click here to register]) do my 1997 31 Open quiet a few years back. Purchased several Ice machine over the years as well. Always a great job at a reasonable Price. Would recommend you contact them. Mention Fred
Best to find one that has everything major you want factory installed. Heat/AC, Generator, etc. Less problems in the long run and probably less money too.
Self contained units make the job of installing a new system somewhat easier. That said there is a lot that goes into the job if the boat has not been previously rigged for AC. You would need to pull power from the breaker panel to the unit, power from the unit to the pump, install pump and sea strainer, pull wire and mount thermostat, install a thru hull for supply water, install a thru hull for discharge water, pull hoses from pump to unit to discharge, install duct work and grills for supply and return air.
I just added a second unit (self contained) to my helm and even with the thru hulls and pumps already installed it still was a big job. If you are paying someone to do all the work be prepared to write a big check. Dbracino is probably providing good advice in finding a boat with AC already installed.
Good luck and hope you find the right boat.
(03-07-2021, 05:53 PM)ReelMagic Wrote: [Only registered and activated users can see links Click here to register]) do my 1997 31 Open quiet a few years back. Purchased several Ice machine over the years as well. Always a great job at a reasonable Price. Would recommend you contact them.  Mention Fred
I actually reached out to them to get an idea on costs. You are super happy with the work? The quote wasn’t cheap. I’m concerned with the long term issues with installing through hull fittings.
(03-07-2021, 07:36 PM)dbriceno Wrote: Best to find one that has everything major you want factory installed.  Heat/AC, Generator, etc.  Less problems in the long run and probably less money too.
I agree with this also however we have been looking for a while and have yet to come across a boat with such low hours, decent price and well kept. Am I crazy for thinking that it’s worth it? I’m an avid boater with my whole life experience on the water but am I missing something?
(03-07-2021, 10:19 PM)jclark003 Wrote: Self contained units make the job of installing a new system somewhat easier. That said there is a lot that goes into the job if the boat has not been previously rigged for AC. You would need to pull power from the breaker panel to the unit, power from the unit to the pump, install pump and sea strainer, pull wire and mount thermostat, install a thru hull for supply water, install a thru hull for discharge water, pull hoses from pump to unit to discharge, install duct work and grills for supply and return air.
Thanks for the input. I feel like I can write a big check for work that’s well done. The boat seems worth it considering it’s near Bristol condition.
I used Mike (Marine Specialists) to install A/C on my 1997 31 Open when the boat was brand new as I ordered it w/o A/C as we weren't sure if we needed it and then decided we needed it... Mike installed it exactly as it would have been if Tiara did it when building the boat, including the through hull fittings/valve/strainer.... All good... Not sure what the unit and all the material costs but Mike seemed to be reasonable in 1997. From what I remember the price was close to what Tiara wanted... Also, he's local should you need support.
(03-08-2021, 04:06 PM)ReelMagic Wrote: I used Mike (Marine Specialists) to install A/C on my 1997 31 Open when the boat was brand new as I ordered it w/o A/C as we weren't sure if we needed it and then decided we needed it... Mike installed it exactly as it would have been if Tiara did it when building the boat, including the through hull fittings/valve/strainer.... All good... Not sure what the unit and all the material costs but Mike seemed to be reasonable in 1997. From what I remember the price was close to what Tiara wanted... Also, he's local should you need support.
Thank you so much. When I do thing on my own they are done with as much precision as I can muster. Good to know mike does quality factory grade work. I much appreciated your response
2 Guest(s)
Getting into tiaras00
