Tiara Open 1981 Tiara Transmissions
Does anybody know what gear ration on the velvet drives were in 1981? I have a 1981 with 454 crusaders thats not getting the right rpms. I suspect the previous owner changed the transmissions putting in the wrong gear ratio's I also believe he tried to compensate with changing the pitch on the props. I pulled the props and I  have 18x19 and I am only turning 3500 rpms at 24mph. Something is obviously wrong. So, does anyone know what the right tranny and prop size is for the 1981 3100 w T454's?
If you contact Tiara customer support and provide your HIN, they should be able to tell you what it left the factory with.
I did but they could only give me the general specs for that boat. They could not give me detailed info with my VIN. I was hopeing they would have the build sheet but, no luck.
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 1,673 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Tiara 31 open crusaders getting when WOT aliyilmaz 5 6,270 03-03-2025, 07:40 PM
  [Tiara Open] Repowering a Tiara 3100 Open with 2 outboards drake 2 3,390 08-21-2024, 09:09 AM
  [Tiara Open] 2006 Tiara 42 Open Transmission Kphillips 1 2,020 07-12-2022, 09:00 PM
  [Tiara Open] 1984 Tiara (Pursuit Hull ID?) open one engine cuts off when put in gear cray4 4 4,296 03-28-2022, 03:58 PM
Last Post: cray4
1981 Tiara Transmissions00
