Batteries
Need new batteries for my 2004 44 Sovran.-(4 start and 6 house).-Any recommendations would be appreciated.
Not sure if your batteries are GEL batteries or not but I replaced my 6 GEL (3 house & 3 Engine) batteries after 17 years of very good service last year with 6 GEL batteries from NAPA.... All were 31 series and so far so good (NAPA 8272)... As a caution you need to ensure your charges (engine & chargers) are set to charge GEL batteries.. M2C
Folkvord (10-30-2021)
I used duracell agm's from sams under $200 for 31's only have a couple year's on them but so far so good. FWIW my last set of interstate lead acid did not make it even two years before boiling off and causing some almost deadly fumes in the cabin.
[-] The following 1 user Likes reeltimebrad's post:
I’m so glad you mentioned those, reeltimebrad. I’m looking to replace my 8 gels with those Duracell AGM’s. Good to hear the positive review. I just can’t possibly imagine how “marine” batteries from WM or the like are worth twice the price. Even if the Duracell’s last only half as long, I still break even in the end.
A word of caution to all that may be changing the type (wet cell, AGM, GEL) of batteries installed to a different type as the engine alternator regulators & the shore chargers may need to be changed to reflect the new type of battery... Charging levels and float values are different for each.... M2C
I though AGM and gel had the same charging properties in that regard. I’ve got the 3208 Cats with Balmar regulators and alternators. Any idea if they’ll work?
I tend to agree GEL and AMG batteries should be interchangeable but based on my Charles Charger info (see attached) there is a difference in charging rate and float levels. As a result I decided to stay with GEL as they were the ones installed by Tiara when the boat was built... M2C
Interesting. Thanks ReelMagic
Most of the Balmar regulators can be reprogrammed to the batteries you change to. I changed out the regulators on my last 2 Tiaras that had Cat diesels. During the setup (using the magnetic screwdriver) you can choose a ton of things like charge rates, how fast the alternators come up (doesn't put a full load on them immediately upon starting) and battery type just to name a few. There were so many variables it was confusing.
  [Tiara Open] 1994 3100 Open Number of Batteries Duke 3 3,255 01-27-2024, 03:33 PM
Last Post: Joeboch348
  [Tiara Sovran] Charging batteries at the dock or on the hard Donaldjames 3 3,424 05-13-2022, 11:45 AM
Last Post: Donaldjames
  Port charges house or port charges starting batteries Matta0413 5 6,412 06-25-2020, 03:08 PM
Last Post: esf
  new batteries honest mark 11 9,284 06-10-2020, 09:08 AM
  [Tiara Open] Need to replace 6 Gel Batteries. (3 house & 3 engine) - 38 Open w/450 Cummin's ReelMagic 6 5,205 05-23-2020, 07:22 AM
Batteries00
