Tiara Open Yearly maintenance
Second season with my Tiara 3100 Open, I put less than 100 hours on the boat the first full season in 2022 on Lake Erie
How often should the engines get a tune-up? mine had plugs, wires, cap, points ect replaced in the fall before I got the boat in 2021.
How often should the fuel filters be replaced?
Oil change every fall or after 100 hours?
I had the impellers and duck bills replaced last year. What is the interval on impeller replacement? I had the duck bills and impellers replaced in 2022 just because I had no idea when it had been done before.
When or should you ever replace the transmission fluid?
Engine tune up along with distributor cap and rotor and new impellers every three years.
Change oil every fall right before haul out. Change transmission fluid every other year.
Clean flame arrestor every year.
Repack stuffing box as needed.
Top off batteries every fall. Replace as needed.
Replace sacrificial anodes as needed.
Fire extinguishers need to be with in 12 years old. Check flares for expiration.
Everything misdirection said (though on my gasser I replaced plugs every spring), plus:
Fuel filters when you do annual oil changes
Impellers every other year
I do engine anodes annually, hull/shaft ones as needed.
Duck bills probably every 3-5 years.
[-] The following 1 user Likes MC1600's post:
Misdirection (05-31-2023)
Ok gonna sound stupid but I have had no luck finding the anodes on the boat.
None visible on hull, ones identified in Crusader Manual don't check out.
Do you have anodes on your prop shafts (you should).
And on your U cooler on the Crusader, there should be a drain (looks like one of the drains on the exhaust manifolds). That drain plug is a sacrificial anode. At least on my raw water cooled crusaders they are.
There should also be anodes on the heat exchanger.
(05-30-2023, 07:23 PM)mc307tank Wrote: Second season with my Tiara 3100 Open, I put less than 100 hours on the boat the first full season in 2022 on Lake Erie
Do you happen to have the Crusader Manual?  I was able to find the one for my 2006 online.  Although I think you could pull any Crusader manual each of which has a very good maintenance checklist that is broken down by Daily, 10 hours, 25 hours, 50 hours, 100 hours.
  Seakeeper Annual Maintenance Cost Sapphire 0 1,494 08-21-2024, 10:05 AM
Last Post: Sapphire
  Tiara Open Progressive Maintenance Schedule Capt James 4 4,785 11-03-2021, 08:25 PM
  [Tiara Convertible] Intro and gen maintenance questions hidalgoa13@gmail.com 0 1,393 04-11-2021, 01:19 PM
Last Post: hidalgoa13@gmail.com
  [Tiara Open] Winterization & Maintenance Procedures - 38 Open ReelMagic 4 4,108 11-03-2020, 07:06 PM
Last Post: MC1600
  [Tiara Open] Arch maintenance firstlight 3 4,254 04-04-2019, 01:22 PM
Last Post: reeltimebrad
Yearly maintenance00
