Tiara Open 2001 3500 Open no fuel to port engine???
The port engine suddenly just quit. (No, I didn't run out of fuel).Fuel filters have been changed recently, fuel solenoid valve was replaced, and the fuses are good. Thinking it may be the relays??? Does anyone have experience testing these? Please advise!
It might help if you could provide additional detail. Type of engine? Recent work done? Were you at hull or planing speed? Any anomalies with engine temp, oil pressure, volts?
(08-31-2021, 09:04 AM)wow Wrote: The port engine suddenly just quit. (No, I didn't run out of fuel).Fuel filters have been changed recently, fuel solenoid valve was replaced, and the fuses are good. Thinking it may be the relays??? Does anyone have experience testing these? Please advise!
Fuel issue was finally determined to be a cracked fuel pickup tube located at the top of the 3/8" aluminum tube just where the NPT threads start! We had this in our hand and couldn't find any issues until it snapped in half in our hand! We were pretty surprised to find a sturdy aluminum tube just snap! We replaced the tube and haven't had any issues in a season!
I’m having same issue. Where is it located?
Joe, Typically a fuel pickup is located on the top of each fuel tank. Look for a fitting with a fuel hose connected. Bob
  38 open bathroom recessed light bulb twilson0929 3 429 08-26-2026, 06:22 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 262 08-21-2026, 02:33 PM
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 347 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 699 07-07-2026, 08:13 AM
  [Tiara Coronet] Port engineer and electronics quit running at same time Tmikac 3 635 07-07-2026, 07:47 AM
Last Post: Tmikac
2001 3500 Open no fuel to port engine???00
