4000 Express - Manually Open Garage Hatch
Help,
My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door.
Thanks,
John
"My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door."
Yessir.  Open the round ports that are in the aft-facing settee & disconnect the pins that hold the hydraulic system to the door & you can open the door by hand.
(11-09-2024, 12:45 PM)bruce@bigrivergroup.com Wrote: "My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door."
Thanks! You're a life saver. Marine tech wanted to put boat on the hard to repair. Tiara has thought of everything.
We have a 3500 Express, I unbolted the top hinges and got the trunk open.
Mike
  38 open bathroom recessed light bulb twilson0929 3 455 08-26-2026, 06:22 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 275 08-21-2026, 02:33 PM
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 357 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 717 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,341 05-22-2026, 06:41 PM
4000 Express - Manually Open Garage Hatch00
