29 open, pre purchase inspection
Hi, new member here hoping to get some advice from actual owners. I am looking at a 1995 29 open. Spoke with the seller and I was told on a previous survey moisture was found on both hull sides and deck . Should I run away? or hire my own surveyor and see just how bad it is? Also any other problem areas i should look for shopping around. Thanks in advance.
(07-07-2025, 05:52 PM)DD-RI Wrote: Hi, new member here hoping to get some advice from actual owners. I am looking at a 1995 29 open. Spoke with the seller and I was told on a previous survey moisture was found on both hull sides and deck . Should I run away? or hire my own surveyor and see just how bad it is? Also any other problem areas i should look for shopping around. Thanks in advance.
Hello,
I own a 1999 -2900 open. I'm surprised to hear that the side hull has any water. I suggest seeing if you can read the old survey. Keep in mind all boat have some type of water intrusion, just how much is what matters. If you cannot get old survey, maybe purchase a meter before you hire inspector.
I'd look at transom and strings where engine mounts. By the way, engine compartment is extremely tight and this can drive up repair cost (might need a hard helmet-lol) above the deck steps starboard side can sometimes get water in from the horn. If there an inspection hatch open it up.
The overall boat is a beast ( great lakes for me) but can take some spray over bow. If you have any specific question let me know - good luck
Thank you for your response. After speaking with the seller and what he told me just over the phone , I passed on even going to look at it. The search will continue.
  3500 Open deck lift piston drmiagi11 2 764 09-03-2026, 04:05 PM
  2001 3500 open, diesel exhaust flanges? North Star 4 1,497 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,117 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 2,792 12-02-2025, 02:13 PM
Last Post: E-MAN
  [Tiara Open] 2006 Tiara 42 Open Powered With QSM 11 675 hp - Thoughts ? DoctorM 5 4,015 10-20-2025, 09:05 AM
Last Post: DoctorM
29 open, pre purchase inspection00
