Threads: 17
Home Port: Lake Ontario
Vessel Info: 2001
31 Open
8.1
The surveyor recommends that the exhaust ports be reseated. Is this a good idea, they seem to be OK. What caulk would I use? 2001 3100 Open.
Threads: 14
11
Home Port: Kings Park, NY
Not sure if I understand the question/concern as the exhaust ports that go through the hull, at least on my old 1997 31 Open and my current 2003 38 open, were fiber-glassed into the hull during manufacture... They are located on the hull side aft quarter near the stern. They are NOT through the stern.... Not sure where yours are located so can't figure out how re-sealing is required. Aren't they fiber-glassed into the hull?
Threads: 14
11
Believe the screws only hold on external covers that direct flow of water around the actual exhaust. You could use silicon to close any gaps but believe they are ornamental and don't affect the integrity of the hull/exhaust tube being waterproof.... M2C
Threads: 17
Vessel Info: 2001
31 Open
8.1
That reinforces my thought, thanks for the info. Sometimes we do more harm fixing things that aren't broken.
