holding tank vent filter
I have a '96 31 Open. Can anyone advise on where the holding tank in-line filter is located? I need to change this and don't recall seeing it. There seems to be very little room where the holding tank is located and am hoping that it is not behind the tank.
Thanks.
On my '95 it is just above and aft of the holding tank.
(12-20-2016, 12:39 PM)czarcone Wrote: On my '95 it is just above and aft of the holding tank.
Thank you for your help. I will look for mine in this location as well.
Look for a line that runs out of the top of the holding tank and follow it to the vent on the side of the hull. If you have a filter, it will be installed in this line and be located near the vent. Mine is tucked up near the top of the joint between the deck and hull just below the rub rail. It is installed just above the holding tank and secured with a nylon electrical wire tie to the plumbing.
on my 98 31 open its just aft of the tank on the port side above my battery boxes
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,731 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,179 10-09-2025, 06:37 AM
  Holding tank collapsing fix giff1 5 2,968 10-18-2024, 06:00 AM
Last Post: egstasea
  [Tiara Sovran] 4400 Sovran Air Conditioning Vent Grills in HELM area. Feetwet 0 1,129 06-08-2024, 10:22 AM
Last Post: Feetwet
  2018 38LS Black water tank location Scottbee 1 1,709 03-11-2024, 10:27 PM
Last Post: Scottbee
holding tank vent filter00
