Threads: 2
Hi All,
I recently purchased a Tiara 3000 which has gas 6.0L Crusaders and a Gen Set and will be kept in Lake Michigan in fresh water. I plan to do the bulk of the maintenance myself and wanted to get input on what else I should be adding to the list of seasonal items. Here is what I have so far...
-Change Engine Oil
-Change Transmission Oil
-Change Gen Oil
-Change Water Pump Impellers
-Inspect Zincs on Hull and in the Heat Exchanger
-Inspect hoses for cracked / leaking
Any other comments / feedback would be welcome.
Threads: 14
2
Not sure if you've got a closed or open cooling system, but if you really want to cover it all and you've got a closed system flushing the cooling system would cover all you engine maintenance items.
A back flush would also give you piece of mind that there is no debris from a bad impellers or lost fins in the system.
Threads: 3
20
Home Port: Lake Michigan
Probably a lot that can be added to the list but here are a few of varying importance:
1 replace fuel filter/water seps
2 Cycle the ball valves on all of your intakes to make sure they operate freely
3 check/clean battery connections
4 check for play in your strut bearings
5 check for play in your steering tie bar (just checked mine and found one destroyed rod end)
6 clean out sea strainers
7 manually trip each bilge pump float switch
8 visually inspect hose clamps and belts
If you have ever gotten a uscg safety inspection they left behind a checklist. I like to run through the list before launching (nav lights, fire extinguishers, etc)
Congratulations on the boat.
The 6.0 is a great engine that doesn't require a lot of annual maintenance. if you don't know the engine history and want piece of mind swapping coolant is always a good idea. otherwise follow crusaders Maintenance intervals and you should experience good reliability.
Threads: 2
Thanks Gents! I'm creating an list in Excel so the above points have been added. The Crusader manuals also have a maintenance check list so I plan on going through that in detail too.
Threads: 15
Home Port: Seattle
Vessel Info: 2005 Tiara 2900 Crusader 6.0L engines
I have the same engines in my Tiara 2900. The engine manual says to change the raw water pump impellers every 50 hours. A local mechanic said to change them every 200 hours. I changed one of the engine impellers at about 150 hours and put in a new one. The old one looked good as new so I kept it as a spare and have not changed the other engine's impeller.
