thru hull transducer on 2900 open
Where is the best location to mount an elongated tru-hull transducer on a 2006 29 open and also a dome radar unit on the hardtop? Thanks
Before you drill a hole in the boat, read on-line about installing Xducers. I would put it in a HD plastic bag of water and set it in different locations in the bottom of the boat and try it first as a shoot thru the hull. Look  for accessible places with minimum interference at cruising speed.
 Most installers recommend Boatlife caulk rather than 5200. If you have to change it, 5200 makes it really tough.
You don't want it to be in-line with any thru-hull fittings and make sure the cable reaches the display. You don't want to cut and splice the cable.
Radars are usually installed as high as possible (for max range ) on the center line of the boat . Keep it away from the GPS antenna, you don't want the radar beam hitting it. And you don't want the radar beam hitting any people .
Put a wedge under the rear of the mount so that you have about a 5 degree down angle. That will level it when running. Again, don't cut the cable. Align the display heading marker to the center-line of the boat when you finish the installation and practice on a clear day.  Capt.  George
Doesn't the engine room have a backing block glassed into the hull under each engine for thru hull mounting?
Mark - Reely Nauti
  38 open bathroom recessed light bulb twilson0929 3 484 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 385 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 763 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,400 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 757 05-12-2026, 10:18 AM
thru hull transducer on 2900 open00
