1986 3600 Continental Stringer Construction
I have a 1986 3600 Continental (Open). Are the stringers under the engines hollow or do the have a solid wood or other material the engine mount bolts bite into? I have a port aft inboard engine mount bolt that is loose and will not tighten up.
Were the stringers designed to be glass only with a passive or no coring?
Thanks,
Rob
Rob
Contact customer service. I had a similar question and they explained it all. 'Ask the expert'.
(07-20-2017, 08:04 PM)drifter Wrote: Contact customer service.  I had a similar question and they explained it all.  'Ask the expert'.
Thanks for your help!
Rob
Rob
Per Tiara Customer Support, Thanks Brian!
"A plywood stringer system set into the hull and glassed into place. All of the structure is in the glass and the plywood is used as a form.
Mahogany was built into the stringer form to provide a stable engine mounting platform. "
Rob
Rob
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,805 02-23-2026, 11:01 AM
  [Tiara Open] 89 3600 open rudder needs replacing BurdenLSU 0 812 12-06-2024, 11:01 AM
Last Post: BurdenLSU
  tv mount for 3600 coronet greenaub 0 711 11-08-2024, 06:14 PM
Last Post: greenaub
  2005- 3600 Open Center Windshield Wiper Motor Cover Replacement Tminus3 1 1,380 03-30-2024, 08:03 AM
Last Post: Makoman
  [Tiara Sovran] 2005 Sovran 3600 bbunch 2 2,005 02-12-2023, 06:15 PM
Last Post: Misdirection
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
