BATTERIES
GOING to replace my (4) house batteries 550cca and my (4) starting batteries 800cca, any recomendations on what brand battery and do you think i should go to 1000cca for the starting batteries?? have a 660 hp cummin qsm11 engine?? thank you
Unless you have changed the house load (e.g. added an inverter) or had problems starting the engines I would probably recommend replacing with similar type and capacity batteries. A higher CCA on the start bank won't hurt anything and also won't cost much more either so it's really up to you. If you change battery type you will also need to change the charging profile on regulator and charger. as for brand I'm not sure there is much difference. I've had good luck with interstate, AC Delco and NAPA.
thanks for the input, greatly appreciated....
(11-01-2019, 02:36 PM)honest mark Wrote: GOING to replace my (4) house batteries 550cca and my (4) starting batteries 800cca, any recomendations on what brand battery and do you think i should go to 1000cca for the starting batteries?? have a 660 hp cummin qsm11 engine?? thank you
Marine batteries are available in four chemical types for different applications: flooded, gel, AGM (Absorbed Glass Mat) and Lithium. Which type you choose is based on your needs (deep cycle vs. starting), the capacity and lifespan you are looking for and your budget.
 I like AGM batteries.......
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
  [Tiara Open] 1994 3100 Open Number of Batteries Duke 3 3,295 01-27-2024, 03:33 PM
Last Post: Joeboch348
  [Tiara Sovran] Charging batteries at the dock or on the hard Donaldjames 3 3,442 05-13-2022, 11:45 AM
Last Post: Donaldjames
  Batteries Folkvord 8 5,574 10-30-2021, 09:21 AM
  Port charges house or port charges starting batteries Matta0413 5 6,428 06-25-2020, 03:08 PM
Last Post: esf
  new batteries honest mark 11 9,328 06-10-2020, 09:08 AM
BATTERIES00
