Tiara Sovran No Power to Stereo and Auxiliary Charger
I recently purchased a 12 volt plugin adapter to charge my iPad pro through the 12 volt auxiliary charger located next to the radio on the helm deck.  It appears that the adapter which was sold specifically for the iPad pro has blown a fuse on the 12 volt power lead that supports both the auxiliary charger and the stereo head end on my 2009 Sovran.
I checked the fuse on the stereo and it is OK.  I checked the panel fuse marked stereo and it is also OK.  I can see that the 12V power lead is split to support both the stereo head end and the auxiliary charger.  I have followed the harness as far as I can see and cannot see any additional fuses.
Assuming there is an additional fuse can anyone tell me where to look for it?  Do I have to pull the microwave unit to provide more access to the back of the helm deck stereo/auxiliary charger mounting points?  If so can you provide some guidance on its removal as it appears that the mounting bracket for the microwave is screwed in from below with no access unless I pull out the refrigerator??
Any help the forum can provide is greatly appreciated!
I would first drop a note to Tiara and get a copy of your ships wiring diagram. Did you check your breaker panel to see if any are tripped?
  [Tiara Open] C-Charles Charger Series 5000 failed ReelMagic 3 1,036 10-27-2025, 09:51 AM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 713 09-07-2025, 11:19 AM
  original tiara battery charger drifter 1 823 07-09-2025, 10:22 AM
  Reinstalling power vent in windshield. 1993 3100 open barefoot446 2 1,274 06-15-2025, 08:09 PM
Last Post: penneyma
  [Tiara Sovran] Shore Power Cable Replacement wwaseleski1953 2 1,393 06-12-2025, 07:50 AM
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
