Ground Fault Breakers
<div>
</div><div>
</div>
Hello</p>
I have a 1999 Tiara Open. The marina I keep the boat in installed a ground fault system to protect against accidental injury. Problem is we trip the breaker as soon as we open up the breaker on the boat. I have someone working in this but just wondering if anyone else has experienced this and where they found the problem lies? Understand that all boat have many different electrical systems at play put wondering if there is a common denominator with Tiara's.</p>
Thanks</p>
Kent</p>
Kent
1999 Tiara 35 Open, Cummins
That should not happen if you flip the breaker with equipment off. Then turn on equipment one by one and see if you can find the problem. An AC or fridge compress so is the most likely cause. By the way, more sophisticated GFI protection systems have an adjustable trip point.
[quote]torchlake99 - 7/16/2014 9:14 AM
<div>
</div><div>
</div>
Hello</p>
Had similar trouble. As soon as I turned on the AC power breaker, the GFCI receptacle would trip. Started to unload one circuit at a time at the bus bars. Once I unloaded the inverter, everything was fine.
Thanks all, we are tripping the breaker with everything turned off on the panel and under the steps just as soon as we flip on the breaker on the ac main panel. Will print out the above and show my electrician.
Kent
  Upgraded to GFCI breakers and now mine pops all the time. '88 3300 open cp4000 10 7,785 03-08-2023, 08:07 PM
Last Post: dplunske@cwpm.net
  tuFUZ0cQ Shore power breakers/ surge protectors MichaelD 2 2,926 04-02-2021, 03:05 PM
Last Post: Harloo
  [Tiara Open] 2002 Tiara 38 open ground issue Sam-n-I 8 8,822 01-02-2021, 10:50 AM
Last Post: sjcrum
  power problem connecting to pedestal with GFI breakers Snowballs 18 19,306 11-16-2020, 09:06 AM
Last Post: Matta0413
  [Tiara Sovran] Low Voltage - Starter ground issue DavidB 1 2,698 08-16-2020, 08:22 AM
WTB Tiara Coronet (1997-2007)
Last Post: JaviAirstream
Today 02:09 PM
3500 Open deck lift piston
Today 10:03 AM
» Replies: 6
How to Put Boat Picture On Left?
Today 09:58 AM
» Replies: 7
2000 3500 Open - Engine Sync Switch (7.4...
11-18-2026 05:48 PM
» Replies: 6
Last Post: joshuawhite
11-18-2026 02:48 PM
» Replies: 3
