J Lounge Removal on 32 Open
Trying to remove the j lounge from the upper cockpit area of my 2005 32open. I removed the 6 lags I can see from inside the storage area but to no avail the lounge is held down tight. Appears to be secured down with some sealant?? Has anyone removed the seat before any help appreciated.
        thanks
I haven't removed anything that sizable from my 98 31 Open, but I've worked around a couple of other items and found most positioned with 5200 in addition to fixed fasteners.  I've had good success with a heat gun warming the materials and using a scraper to get in the tight places to break the sealant bonds.
Good luck.
A length of piano wire around two dowels can be used as a saw along with lots of WD40 to cut through a sealant. Wooden wedges for pry's also help. Capt. George
Thanks for the help. Will try the piano wire.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 621 11-16-2026, 01:54 PM
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 449 11-14-2026, 05:25 PM
  [Tiara Open] 36' Open interior lights Rick B 0 108 11-14-2026, 12:22 PM
  [Tiara Open] Cockpit bolster removal Rick B 0 96 11-14-2026, 12:15 PM
  38 open bathroom recessed light bulb twilson0929 3 715 08-26-2026, 06:22 AM
