prop nuts
Hi, quick question on the order of the nuts.  I just put my wheels back on and noticed my 31 and my friends both have / had the smaller nut on first against the prop and the larger one aft.  But looking around the yard, all the other boats (sea rays silvertons luhrs) are opposite. with the heavier nut on first. so thats how i installed mine.
Does it matter? I didn't know if Tiara did it this way for some reason or not.
thx
[Image: 3573d04f3374f10e95b717ff2078778a.jpg]
How they were
[Image: 951103256bd501daa293c704da9c7997.jpg]
Hard to see but how I put them back on
Smaller nuts goes on first.
"Contrary to commonly held beliefs, when assembly is complete, the half-height nut should be against the propeller hub, having been installed first, while the full-height nut is farthest from the propeller hub, having been installed last. The logic for this seemingly counterintuitive approach goes like this: when the first nut is installed and torqued down, it carries all the load or tension. When the second nut is installed against the first nut and it is torqued, much of that load or tension is transferred to the second nut. Thus, it only stands to reason that the second nut (the one that carries the majority of the load), should engage more of the propeller shaft with more threads."
Interesting, thx! I guess i"ll change them before launching. I figured there was some reasoning. thx
You are right about one thing, most installers put the large nut on first and that's wrong. Do some research on-line using Google and you will find what BPRO says.  Capt. george
Yep! What those guys said. Funny. I bet 80% at my club are on wrong
Sent from my XT1080 using Tapatalk
  2003 Tiara 31 Open w/Cummins 6BTA 5.9 330HP Prop size alhalpern 1 1,972 06-29-2022, 06:29 PM
Last Post: Misdirection
  Prop Removal Questions - Harmonic Prop Remover ardoski14 2 3,197 06-03-2021, 06:40 AM
Last Post: reeltimebrad
  prop shafts honest mark 1 1,981 03-08-2021, 07:47 PM
Last Post: MC1600
  [Tiara Open] Prop options for 2001 Tiara Open (Gas) IrvingVet 3 5,336 05-09-2019, 08:50 PM
Last Post: Lured Away
  prop pocket plates justrollin 6 10,670 05-30-2018, 02:18 PM
Last Post: wasitim
