cockpit courtesy lights
Anyone know what factory lights where on the 1998 3100 open cockpit,under the gunwall between the rod holders?
I don't remember. Can you pull one and see if there is a manufacturer and part number on it? Most manufacturers are going to LED and are redesigning all of their lights. You may not be able to find the exact light. I would go to your local Marine Supply store and see what they have. You can also look it up in a catalog and pick something that is close in size.
Good Luck.
It doesn't really matter what is there, it's out of sight, right? If they don't work, it's probably just a bulb burned out. If you want to replace them, just about any surface mount light will work. Or, you could consider just buying LED bulbs for them--you can get them in any color you want. Or, replace them with multicolor LEDs for the cool factor.
\"Buoy Scout\"
Thanks Guys They are old and replaceing is the way to go with LEDs whats under there is Dyna Plastic DOT SAE PC-73 lights outdated. Im going with new ones thanks for your help.
(09-06-2013, 03:27 PM)justrollin Wrote: Thanks Guys They are old and replaceing is the way to go with LEDs whats under there is Dyna Plastic DOT SAE PC-73 lights outdated. Im going with new ones thanks for your help.
@justrollin sorry to bump this back up, but may i ask what you replaced them with?  Only the port side was out on ours, but the fixture socket was too corroded to be saved and we are having guests aboard Friday.  I plan to do some cool led strip lights ultimately, but for now just wanted to get something up there and not have to change the other side too.
Photos attached for reference if anybody else needs to see these.
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,151 11-10-2024, 09:17 PM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,773 08-18-2024, 07:22 PM
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 1,058 06-15-2024, 07:50 PM
  1994 43 Open Cockpit Courtesy Light Fixtures carbon20 1 2,212 11-12-2023, 11:37 AM
Last Post: Afarneti
  [Tiara Open] 3100 Dash lights tatum051 3 5,905 07-20-2023, 05:47 AM
Last Post: MuskyHuntr
