Tiara Open Kicker install on 1990 31 open
Just bought a 1990 31 open
Has anyone seen a kicker motor on swim step or mounted on the transom.
Any ideas on the size of motor needed to push boat 2 to 4 mph.
I thinking of a Yamaha 9.9 high thrust
I also like the Honda 15 hp
I think mounting on the transom would be better secured, using a jack plate to lower the motor into the water.
The 454'S have been replaced and have only 300 hours.
I don't want to rack up a lot of hours on the big motors
Thanks Doug
I've not seen one on a Tiara, but have on other boats similar in size. I do not think a swim platform will be strong enough to support a kicker. You will likely need a transom mount.
As far as size, you will not be able to get past hull speed (about 6 knots) for your boat. So you need to work with a dealer/manufacturer to determine what size can push you to that speed with out working the motor too hard.
I also have a 31' Open in Washington and have been thinking about a trolling motor. Did you ever find a means of installing one on your boat?
Thanks!
We have a 2700 with a Suzuki 9.9 kicker.. I’d probably go with a 25hp on a 3100 and have seen a few 3100s with 25hp kickers
[Image: 67aa677e73a1710312365ff1e8b43bfd.jpg]
[Image: e06092ece698eb892f89ee5b47343265.jpg]
Hey Scurvy, I realize this is a well aged thread, but would you happen to be able to supply the pics that are now dead in your reply?
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,462 03-27-2026, 08:07 AM
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,752 05-25-2025, 08:25 PM
  Trailering a 32 open douellette48 3 3,076 02-07-2025, 08:46 PM
Last Post: Hifirush
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 7,442 12-02-2024, 09:25 AM
Last Post: Hooper
  Looking for a 2006 or newer 32 Open Matta0413 3 2,892 02-04-2024, 10:58 AM
Last Post: Matta0413
