Tiara Open Repower an '84 3100 open with V6 or V8 diesels
Has anyone repowered an '84 3100 open with V6 or V8 diesels?  My preference would be the Mercury V8 370hp but if the fitment will not allow, then the Mercury V6 270 TDI is my next choice. I thought about the Hyundai Seasall S270 but the cost is prohibitively high. Any insight welcomed. TIA.
(09-05-2021, 10:26 AM)SaKiawa Wrote: Has anyone repowered an '84 3100 open with V6 or V8 diesels?  My preference would be the Mercury V8 370hp but if the fitment will not allow, then the Mercury V6 270 TDI is my next choice. I thought about the Hyundai Seasall S270 but the cost is prohibitively high. Any insight welcomed. TIA.
Interesting.  Keep us posted on your findings.
I have an '83 31' Open with 454 Crusaders, and after research, going with the Yanmar 315 diesels as the repower choice.
Can you provide any insight to what the Repower cost was and how the new motors are preforming?  Thanks!
Did not do the repower due to high costs and engine unavailability.
I wonder if the exhaust ports would have caused an issue. Could be wrong but I think the Crusaders (Gas) like mine, the exhausts ports were below the waterline and on the diesels, they were above.
Being more pro on diesels than gas for a 37 or bigger the Yanmar 315 hp diesels as a replacement would be a direct replacement WRT to shafts, props (may need a pitch/diameter change) but are similar to the 454 gas you have... Several manufactures offered Yanmar 315's as well as gas 454's due to the similarities that allowed them to use the same shaft, struts, props (minor change required). Fuel economy is better with the Yanmar's but don't believe the expense justifies them. From experience, my buddy has  Yanmar 315's in his 37 Cruisers Inc. express and has found out the same boat w/gas 454's is faster but uses more fuel (est. 10%) so the diesels don't justify the expense... Additionally, they were made for cars/trucks used offroad and not for marine use. Marinizing them for marine use has dissimilar metals touching each other that caused electrolysis. Additionally, the oil pans are sheet metal and rusted away due to the exposure to a salt environment. M2C
Cummins 6bta 330HP with ZF220 gears would be my preference. Above all, I'd stay far away from Merc's.
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,462 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,972 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,752 05-25-2025, 08:25 PM
  Trailering a 32 open douellette48 3 3,076 02-07-2025, 08:46 PM
Last Post: Hifirush
  Looking for a 2006 or newer 32 Open Matta0413 3 2,893 02-04-2024, 10:58 AM
Last Post: Matta0413
