4000 Express...couple of comments/questions
Cross Posted to owners group on Facebook.
On my 3rd weekend with my new to me 40 Express. First off, love the boat and the ride.
Some things I have questions on:
The indirect doce lighting which are fluorescent bulbs with ballasts are making a period clicking noise.  They work but the clicking is annoying?  Anyone encountered this and suggest a fix?
Why are there 2 freshwater pumps?  No accumulator?
Onan Genset DC breaker keeps tripping.  Works most times but also trips at others.
Foredeck areas collects water. Puddles up around anchor windlass deck clear etc.  Zero slope so the water just sits.    Was thinking of having a glass guy install a weeping hole into anchor locker so there is at least a path for the water to go other than through the hardware mounting holes.  Deck is solid but had elevated moisture levels.     Seems like a flawed design in my opinion.
I have never heard fluorescent lights click. Not sure what that would be. Did you try a new bulb?
My 41 has twin freshwater pumps without an accumulator. By running both it keeps the water pressure pretty steady and powerful. Good flow with both running.
I am not sure about the DC breaker. Is it doing it at startup or while running? If at startup you may need to check the starter and see how many amps it is drawing.
I think the anchor locker already has a drain, no?
.pdf   Owners-Manual-diagrams.pdf (Size: 256.51 KB / Downloads: 21)
The DC breaker trips often when the temp is high. Replacing the impeller AND cleaning the cooler have fixed that for me.
  Seriously considering a '98 4000 Express Cruiser... Have some questions... amajamar 3 1,151 10-28-2026, 01:07 PM
Last Post: Gustaf
  Delaminated hull 2003 4000 express Steve Bosse 6 1,502 10-12-2026, 03:46 PM
  2001 5200 Express knot@work 0 1,972 12-02-2025, 09:28 AM
Last Post: knot@work
  1996 Express 3500 TomReaginCarney 2 1,308 06-10-2025, 08:04 AM
Last Post: TomReaginCarney
  3500 Express Factory Option Trunk Dinghy Outboard Mount Picture JMGCINCY2023 0 907 05-18-2025, 07:50 PM
