Tiara Open Transom thickness on 3500 Open
    How thick is the transom on a 3500 Open?  Am going to buy an Imtra SX50 stern thruster, and the pipe that carries the cables through the transom is available in two lengths - 50mm and 150mm.
I basically need to know if the transom is less than or more than 50mm thick.
Thanks!
Since 50mm is about 2", and the way everything else on a Tiara is made, I would expect the transom is thicker than that.
It's definitely less than 2 inches. my 32 is about a 5/8 all fiberglass no coring and if you include the swim platform it's still less than a inch overall.
(04-05-2021, 03:07 PM)reeltimebrad Wrote: It's definitely less than 2 inches. my 32 is about a 5/8 all fiberglass no coring and if you include the swim platform it's still less than a inch overall.
Thanks very much, I'll go with the 50mm version.
You can get a fairly good idea by measuring the distance (A) inside in the bilge from the trim tab bolts that come thru the hull bottom to the transom inside surface, then on the outside under the boat measure the distance (B) from the same trim tab bolts to the outside transom surface. B – A = Transom thickness
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 715 11-16-2026, 01:54 PM
  3500 Sovran trimtabs drprunner 0 137 11-14-2026, 03:44 PM
Last Post: drprunner
  38 open bathroom recessed light bulb twilson0929 3 776 08-26-2026, 06:22 AM
