water tank leak
Frown
I have a 1991 tiara express with a water tank leak. I cannot see where the leak is but it stops at about the 30 gallon level. the tank is an 80 gallon tank. does anyone have a solution. I was considering cutting offront of the tank and fitting a new plastic tank inside the aluminum tank. then put straps to hold the new tank. any ideas would be welcome.
I assume the tank is draining into the bilge.
Try closing off the vent hose with a clamp, then check the gasket on the fill and close it. Next I would put air pressure in the empty tank via the drain hose and listen for an air leak. Maybe some recent worker drilled into it or ran a screw into it. Capt. George
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 947 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,278 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,538 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,326 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,862 07-30-2025, 03:18 PM
