Tiara Open 2003 3100 Open needs shaft seals
    I just had a survey completed on a 2003 3100 open I have under contract. The report came back and said that both of my shaft seals need to be replaced. I’m trying to get a ballpark cost for this repair so I know how to address the issue with the seller. Any help would be greatly appreciated thanks
Depends…
1. If the dripless system components are still good, the seals just need to be replaced, and there are new ones already on the shaft, probably just a couple hours labor since it can be done in the water.
2. If new seals are not already on the shaft, that would be a bit more because the shaft has to be pulled back and would take more labor and possibly (probably) hauling the boat.
3. If the entire dripless system needs to be replaced, you’re looking at about $1000 in parts plus #2 above.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 627 11-16-2026, 01:54 PM
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 456 11-14-2026, 05:25 PM
  [Tiara Open] 36' Open interior lights Rick B 0 114 11-14-2026, 12:22 PM
  38 open bathroom recessed light bulb twilson0929 3 718 08-26-2026, 06:22 AM
