Charles C-Charger
Is the Charles C-Charger a battery charger or is it as described on their manual a"Marine Electronic Alternator Regulator".  I thought a charger and a regulator are not the same.
A charger and regulator are not the same, but Charles very confusingly labeled their alternator regulators 'C-Charger'. They also labeled their battery chargers as 'C-Charger' to add to the confusion. Bottom line is it could be either.
It would seem that I have the regulator, however on the AC panel there is a switch "Battery Charger" which I can not locate. Where could it be hiding?
(07-08-2025, 09:40 AM)hiccup Wrote: A charger and regulator are not the same, but Charles very confusingly labeled their alternator regulators 'C-Charger'.  They also labeled their battery chargers as 'C-Charger' to add to the confusion.  Bottom line is it could be either.
What year and model boat do you have?
2001 3100 open 8.1 engines.
The charger is on the inside bulkhead behind the panel behind the lounge seat.  It's dead, replaced it with a 15 volt 2 bank seems to be working now.
  Charles AC Master Control Unit Knot On Call 6 2,144 06-03-2026, 03:46 PM
Last Post: Knot On Call
  Charles industries Voltage Regulator on Cummins QSM11s Feetwet 7 5,614 01-25-2025, 06:31 PM
  Battery charger Location-1994 31 open Rt31 2 2,618 05-30-2023, 11:40 AM
Last Post: Rt31
  2001 3500 open 6BTA Charger replacement recommendations Crown Royal 0 1,288 05-24-2023, 10:22 AM
Last Post: Crown Royal
  [Tiara Sovran] 2004 52 Tiara Sovran Salon Charles Ind. Master Controller ACMC 50I-1 Knot On Call 2 2,322 05-21-2023, 08:32 AM
