Crusader rpm cruising speed
What is the most fuel efficient cruising rpm running for a 2006 Tiara 2900 with 6.0 liter Crusaders?
Tiara sent me a number of documents when I bought my 3300 Open which included a graph with the RPM range, speed and GPH during its initial test run. If I remember correctly, for my boat is was around 3000 RPM, right before all 4 barrels kick in. You can try to email them to see if they have it for your boat at cr@tiarayachts.com and put the HIN # in the subject line. This can change a lot over the years as there are many variables like weight, bottom paint condition, prop wear etc. You should be able to hear when the 4 barrels kick in and then throttle back some, most likely your current sweet spot. If you want to know for sure, I would install a fuel flow meter to check yourself. A option that I would like to install at some point.
  Cruise speed- 2900 Open DEG228 3 3,022 07-29-2025, 04:21 PM
Last Post: DEG228
  1995 Tiara 4000 Express - Trolling speed bcronk 1 4,693 11-08-2023, 04:40 PM
Last Post: dan@superstamper.com
  Beeping sound at increased speed Doghouse1 7 5,465 06-04-2023, 08:52 AM
Last Post: bhaslehurst
  3500 Open/3600 Sovran Extended Cruising/Overnighting radiocontester 21 30,568 06-04-2018, 03:02 PM
Last Post: LI_Sound
  Control of boat at low speed Griff 8 14,809 03-07-2013, 12:33 PM
Last Post: ReelNauti
