Beeping sound at increased speed
After moving on plane there is a beeping sound all gages are normal
After decreasing speed sound will slow down and stop when Idling
Is it the same sound you get when you first start up? If so, I’d start with examining oil pressure. Don’t trust the gauges at the helm and toss a mechanical gauge on the motor to rule that out.
Thanks for info. When I tip console back two alarms one on starboard one on port right side alarms when keys are on port side is the alarms while underway
Not knowing what motors you have, but if you have gas motors, the engine alarm goes off for one of three reasons.
Oil pressure, engine temp, or transmission temp.
First things first. Check your oil, and transmission fluid levels. If their fresh water cooled, check antifreeze levels.
6bta5.19 Cummins
I’ll check what you said thank you
Ok, I'm not sure anything I provided applies to diesel's, but that would still be a good place to start.
Thanks to all it was a loose ground bus bar
Regards
(06-20-2022, 06:25 PM)Doghouse1 Wrote: Thanks to all it was a loose ground bus bar
Regards
I have the same engines and an intermittent alarm going off when on plane.   All my gauges are reading good.   Where did you locate the loose ground?   Thanks
  Crusader rpm cruising speed pwilbur49 1 1,050 05-11-2026, 03:09 PM
  Cruise speed- 2900 Open DEG228 3 3,023 07-29-2025, 04:21 PM
Last Post: DEG228
  1995 Tiara 4000 Express - Trolling speed bcronk 1 4,693 11-08-2023, 04:40 PM
Last Post: dan@superstamper.com
  Control of boat at low speed Griff 8 14,820 03-07-2013, 12:33 PM
Last Post: ReelNauti
