Docking Lights
I have a 1987 36 Open. The docking lights don't work. I want to being the process of troubleshoting but the boat is in the water. I was goingt to start with with the switches to turn them on. How do I get behind the swiches that are on the side on the helm area? Anyone ever try this?
If they are loaded into a panel that is attached with screws, remove the complete panel.
If you don't want to go through that, check for power at the light (when the switch is on) , the ballast or the relay if the lights utilize a ballast or relay.
Brian
They appear to be the OEM pull-on switches. I do not see any screws. I will have to hang over the front and remove a bulb to check. Thanks
You could send a picture to CR@TIARAYACHTS.COM and I will take a look at it. The pull on switch is not familiar to me.
Brian
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,156 11-10-2024, 09:17 PM
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 1,069 06-15-2024, 07:50 PM
  [Tiara Open] 3100 Dash lights tatum051 3 5,912 07-20-2023, 05:47 AM
Last Post: MuskyHuntr
  [Tiara Open] Red led control panel lights out lakesidevu 0 1,486 06-22-2021, 01:05 PM
Last Post: lakesidevu
  [Tiara Open] No Indicator Lights on AC Section of Breaker Panel It's A Need 3 3,806 12-26-2020, 10:11 AM
Last Post: Jimmy
