1996 3300 Open Wiper length and sweep
Hi all,
I have a 1996 3300 Open and I need to replace the windshield wipers.
On the Marinco AFI website for wipers, I am asked to specify a sweep angle of 65, 80, or 110 degrees… wiper motor post length, and both the wiper arm and wiper lengths.
I am having trouble finding these specs for my boat…. does anybody know these specs to share for my boat?
Thank you!
Scott
Why not measure for your self? A protractor for the sweep and a ruler for the arm length and blade length. The post length can be taken off the old unit or measure the thickness of the windshield frame and call AFI. I doubt that this spec will be available anywhere except from Tiara.  Capt. George
(05-13-2015, 07:20 AM)Uhehner Wrote: Why not measure for your self? A protractor for the sweep and a ruler for the arm length and blade length. The post length can be taken off the old unit or measure the thickness of the windshield frame and call AFI. I doubt that this spec will be available anywhere except from Tiara.  Capt. George
Thank you Capt George.  Indeed your correct.
Tiara was able to provide me with the following information:
Original wiper specs (Tiara part number followed by vendor's if available):
3342290 motors, AFI GM2 37281 no longer made.  I do not know sweep angle.  We believe AFI 82182 to be a possible replacement, but this is unconfirmed.
3341940 arms, OEM only, $63.36 each
3341960 blades, OEM only, $40.96 each
The technical staff at Marinco AFI took my 1996 Tiara 3300 Open windshield photograph with dimensions and made the following recommendations for anyone else who may be of interest:
The motor you currently have is the AFI 2000.  The replacement motor is the AFI 1.5, and is limited to arm length and blade length.  The dimensions of the AFI 1.5 can be found in out catalog.  [/url]http://www.delzer.com/powerproducts/globalmarinecatalog/#257/z
Based on the information you provided of a windshield 40.5” H X 28.5” W , and a AFI1.5  wiper motor with 2.5” shaft.  The max height of the blade would be 22”, so you would not get the 6” from top and bottom for your line of sight.    I would recommend the following:
Wiper motor      part #71082       [url=http://www.marinco.com/en/71082]http://www.marinco.com/en/71082
wiper arm            part #33037A    http://www.marinco.com/en/33037a
wiper blade        part #33022B     http://www.marinco.com/en/33022b
If you have the room for an AFI 2.5 motor  http://www.delzer.com/powerproducts/globalmarinecatalog/#256/z you can get a 24” blade.
Wiper motor      part #82082       http://www.marinco.com/en/82082
wiper arm            part #33092       http://www.marinco.com/en/33092
wiper blade        part #33024S     http://www.marinco.com/en/33024s
You may have to change the sweep angle of the motor you purchase for your application.  All of our motors can be set to 45, 60, 80, or 110 degree sweep.
I hope that this may be helpful for someone else as well.
Best,
Scott
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 638 11-16-2026, 01:54 PM
  [Tiara Open] 36' Open interior lights Rick B 0 121 11-14-2026, 12:22 PM
Last Post: Rick B
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 586 08-31-2026, 10:34 AM
Last Post: Herrema4
  38 open bathroom recessed light bulb twilson0929 3 726 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 559 08-18-2026, 02:11 PM
