Bluetooth on 36 Sovran Bose 3-2-1
I am trying to install a bluetooth adapter on the Bose 3-2-1 system in a 2005 36 Sovran.
I have located an adapter from Crutchfield that I think will work, however it requires a 110V feed.
In checking behind the Bose unit, I do not see a 110V outlet, the wire(s) just disappear through the bulkhead.
Does anyone know where the electrical source for the Bose unit is located?
2005 36 Sovran
Cummings 6C-AT 480
I have a 2006 36 Sovran.  There is a outlet directly behind the Bose unit on mine.  What blue tooth are you looking at?
John
36 Sovran, Cummins QSC
John, I ordered it from Crutchfield $60.00. I will take another look but did not see an outlet. My unit sits on a shelf in the "pantry" , the closet just to the left of the companion way. Here is a link to their site
Thanks for the link.  My unit sits in the same place.  The outlet is directly behind the 321. Tiara could have made a change from 2005 to 2006.  Mine was one of the last ones made.
John
(12-30-2015, 01:52 PM)jhhall Wrote: Thanks for the link.  My unit sits in the same place.  The outlet is directly behind the 321. Tiara could have made a change from 2005 to 2006.  Mine was one of the last ones made.
No such luck for me.  No outlet, so we had to remove the coffee maker and use the outlet behind that and fish the wire over to the Bose.  Now all we have to do to use the bluetooth is flip the circuit breaker for the coffee maker.
2005 36 Sovran
Cummings 6C-AT 480
(12-29-2015, 04:50 PM)Outlaw Wrote: I am trying to install a bluetooth adapter on the Bose 3-2-1 system in a 2005 36 Sovran.
good question, let us know if you get the solution maybe you already have.  I wanted to add my Ipod, so I just reached behind and plugged in a 2 wire rca plug to mini plug and use the earphone plug for my ipod.   There is another adaptor for the other apple pins as well.
fwiw I think there is a 110 panel in the engine compartment right in the middle in the engine compartment, I believe you have to unscrew a panel.
  2006 3600 Sovran Final Pursuit 3 5,667 08-09-2025, 02:35 PM
Music Tiara 44 Sovran Amplifier tburling1958 3 3,258 04-01-2022, 10:05 PM
Last Post: Folkvord
  2008 sovran 3900 Steering Hub / Drive by Wire VPelliccia 1 2,278 03-20-2022, 06:53 PM
Last Post: f02eric
  bose spekers dduca@comcast.net 4 3,666 01-27-2022, 07:20 AM
Last Post: MC1600
  Polk Stero/Bluetooth Inoperative jvsodano 1 2,425 09-25-2021, 08:36 AM
Bluetooth on 36 Sovran Bose 3-2-100
