Leaking Washer Nozzle
In my new to me 4500 Sovran I noticed the washer fluid nozzles are leaking when I have the fresh water pump on(noth port and starboard).  After some research it looks like the nozzles are run by a solenoid and likely the solenoid is stuck open.  Does anyone know where the solenoid is and is it something I can repair/reset or do I need to replace the solenoids.  If I need to replace any clue where to get them?
Not sure where it is on your boat but on my 2003 38 Open it's in the engine room on the forward bulkhead- starboard side....
Same as in my 41 open. Stbd side forward bulkhead in front of the engine.
Thank you.  Any idea if I have to replace the solenoid(s)? or if I can just reset it somehow?
(05-12-2020, 02:49 PM)Sans Peur Wrote: Same as in my 41 open. Stbd side forward bulkhead in front of the engine.
The solenoid should be normally closed, meaning shut when it has no power. If itis staying open it may just have some built up crap in it. Remove the solenoid and see if you can blow it out with an air hose. Maybe even pour a little CLR in there and see if it clears it. Make sure the CLR doesn't get into the water system. That would not be a good thing.
If it doesn't work there may be a name or part number on the actual somewhere on the solenoid.
Edit: I went on Google and typed in Marine 12 volt water solenoid and up came a ton of them some brass with stainless steel pieces. Most looked like the one on my bulkhead. You just need to thread size.
I ran them for a little while for a few times and it cleaned out some kind of debris from the solenoid and they are no longer leaking. Maybe from when the boat was winterized? Thank you.
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,446 05-22-2026, 06:41 PM
  2001 40 Express - Windshield Washer Will Not Stop bruce@bigrivergroup.com 1 723 09-02-2025, 06:19 PM
  1993 Tiara Sport 220 Fuel in the Bildge (Leaking tank) bradcool 1 877 01-21-2025, 08:50 AM
  Center windshield still leaking brad 2 2,091 07-17-2023, 07:52 AM
Last Post: brad
  Windshield Washer solenoid location 02-3100 jmarlo 4 4,143 05-10-2023, 09:46 AM
Leaking Washer Nozzle00
