Threads: 1
Home Port: Chesapeake Bay
Vessel Info: 1997 Tiara 4000 Express
Catepillar 435 HP x2
I just bought a 1997 400mid cabin express, The fresh water smells awful. I bought 2 cans of water fresh water brightener but the containers say "do not use with aluminum tank",
What kind of tank do I have & how best to remove odor?
Bruce
Threads: 2
Home Port: Long Island
Vessel Info: 2017 Tiara 44 Coupe
Small amounts of bleach, flush and re bleach till odor is under control.
Threads: 2
we had the same problem and did the bleach/flush/refill. took a couple of tanks, but it's coming under control. I'd still not drink the water from. the tanks. but its fine for everything else. the more you turn over your water, the fresher it'll be
Threads: 6
Home Port: Chesapeake Bay, Middle River
Vessel Info: Buying a Tiara 2001 3100
I agree with the others and I use the bleach method, multiple times. You should check is the strainer on your water pump a few times while going through the process because any growth in your tank could clog it as you try to pump through all of that water.
