I would like to know where is the pump relay panel on a 2013 sovran 39
03-16-2018, 10:26 PM
My 43 has the pump relays located in the ER right next to the condenser control boxes . Should be a small box with a wire leading to the pump and separate wires leading to each control box. If you can't find it trace the wire back from the pump. It will terminate at relay or a control box (if only serving one system). If your boat has self contained (not split gas) units it's possible the relay is mounted next to one of the cabin systems.
| [Tiara Sovran] Removing Salon Door in 2004 Tiara 44 Sovran | Feetwet | 4 | 3,763 |
06-08-2024, 10:10 AM Last Post: Feetwet |
| 3900 Sovran Owners Question - Seating in Salon Area | minnehahas | 2 | 2,149 |
05-25-2023, 10:36 AM Last Post: Donaldjames |
| 2004 52 Sovran Salon upper salon headliner replacement | Knot On Call | 3 | 4,346 |
07-20-2020, 12:08 PM Last Post: Knot On Call |
| Tiara 3000 Open salon berth | Flatliner | 0 | 1,630 |
05-11-2020, 08:26 AM Last Post: Flatliner |
| Need salon table base and posts | Metyson1 | 5 | 6,159 |
12-29-2018, 09:31 PM Last Post: jclark003 |
| 1 Guest(s) |
