VDO sending units
It's been mentioned here using VDO sending units with VDO gauges.  How important is this?  For example should VDO oil pressure sensors be used with VDO gauges?  In the Crusader parts manual both sensors are listed for the oil pressure gauges.
need to make sure the senders impedance range matches that of the gauge, whether you use VDO or some other manufacturer. Keep in mind some VDO senders are floating ground normally open or normally closed depending on the gauge type and some of their gauges expect impedance ranges not normally used by other/US manufacturers. So in some cases you may not have a choice but to use their sender.
I'll check it out. I believe VDO has it on their web site.
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 519 02-18-2026, 09:15 PM
  [Tiara Open] Freshwater & blackwater tank sending units - Length bruce@bigrivergroup.com 2 1,377 07-17-2024, 08:24 AM
  [Tiara Open] Fuel gauge sending unit Hartsnet 1 1,451 06-23-2023, 03:14 PM
  Oil pressure sending unit on twin disc Renegade93 0 1,280 06-14-2022, 04:57 AM
Last Post: Renegade93
  Tiara 4000 Express Gray Water Sending Unit Replacement jdalto@yahoo.com 5 3,775 10-29-2021, 01:36 PM
Last Post: jdalto@yahoo.com
VDO sending units00
