Tiara Convertible Second Tiara. Most recent 1985 Tiara 2700
1985 Tiara 2700 with two 260hp MerCruisers.  Has anyone repaired or replaced the cutoff switch or lever? My engines are cutting out.  Please help if you can add a repair or replacement ideas.  Thanks.
Give us more information about what you call a cut out switch or lever. This is a term I never heard before.
This cutoff switch is unique to an I/O. When you shift from Forward to Reverse (or vice versa) this cutoff switch turns the engine off for a micro second to allow a smooth shift without stripping them. I need help on how to adjustment or determine they are beyond repair.
I had never heard of this so I looked it up. Here is a good article describing it. Not sure if this help you or not.
https://forums.iboats.com/forum/engine-r...stem-works
I had this problem on my 1984 2700. In my case it was a sticky lower shift cable. After I replaced the cable I had no more problems.
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,079 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Tiara 31 open crusaders getting when WOT aliyilmaz 5 6,511 03-03-2025, 07:40 PM
  [Tiara Open] Repowering a Tiara 3100 Open with 2 outboards drake 2 3,578 08-21-2024, 09:09 AM
  [Tiara Open] 2006 Tiara 42 Open Transmission Kphillips 1 2,109 07-12-2022, 09:00 PM
  [Tiara Open] 1984 Tiara (Pursuit Hull ID?) open one engine cuts off when put in gear cray4 4 4,497 03-28-2022, 03:58 PM
Last Post: cray4
Yesterday 05:08 PM
