Threads: 3
Home Port: Long Island Sound
Vessel Info: 2002 38 Open 450 cummins
The A/C unit worked prior to the pump seizing up. Sounds like a lot of wasted wear and tear for these pumps to run constantly. My controller looks a little different than shown. Thanks for the reply
Threads: 14
11
Home Port: Kings Park, NY
Was the pump always on or only when cooling/heating?
Threads: 3
Not sure the only time I saw it work was on the sea trial. We knew the pump needed to be replaced but no other issues.
Threads: 14
11
As a result I would look at the A/C manual to see if you can set via DIP switches or via the Passport I/O programmable display(setting) P-12 and make it only when the A/C unit is cooling or heating.. I have 2 A/C units on my 38 Open and the pump only functions when one or both units call for cooking/heat.. M2C
Threads: 3
Going to look at the manual today. Hopefully I can reprogram
Thanks for the help
Threads: 20
Home Port: Suffolk County, NY
Vessel Info: 2001 38 Open; Cummins 6CTA8.3 450HPx2
2001 38 open, my pump is under the starboard engine, you need skinny log arms
