Fresh water tank
I just bought a 1997 400mid cabin express, The fresh water smells awful. I bought 2 cans of water fresh water brightener but the containers say "do not use with aluminum tank",
What kind of tank do I have & how best to remove odor?
Bruce
Small amounts of bleach, flush and re bleach till odor is under control.
The bleach method works. But I use Starbrite Water Treatment and freshener in my aluminum tank, never had an issue.
You'll have two water tanks, one forward of the center fuel tank and one to starboard of it. This label is on my "to starboard" water tank.
My personal choice would be the "bleach, fill, empty, repeat" method. Not sure what's in that Starbrite stuff that makes them say not to use it on aluminum but I'd probably heed their warning.
Hope it works out well for you!
we had the same problem and did the bleach/flush/refill. took a couple of tanks, but it's coming under control. I'd still not drink the water from. the tanks. but its fine for everything else. the more you turn over your water, the fresher it'll be
I agree with the others and I use the bleach method, multiple times. You should check is the strainer on your water pump a few times while going through the process because any growth in your tank could clog it as you try to pump through all of that water.
  [Tiara Open] New To Me Tiara 36 Open Water System Question jayacarrion@gmail.com 2 2,291 08-29-2023, 05:30 AM
Last Post: bandnew
  38' OPEN transom mounted bait tank Groper 3 3,872 03-26-2023, 01:42 PM
Last Post: seasalt32
  [Tiara Open] Holding Tank Sensor GeoDoc 5 4,862 05-04-2022, 10:43 AM
Last Post: GeoDoc
  Holding Tank leaks Jfhaas 6 4,929 02-22-2022, 09:52 AM
Last Post: Maxwell
  [Tiara Sovran] Taking on water when running 52Frankfort 13 8,159 02-08-2022, 02:06 PM
Last Post: Matta0413
Fresh water tank00
