98 3100 Open Flooring issue
        Hi, on our well maintained 98 3100 we recently had an issue where the AC unit under the berth froze up.  We had the unit replaced but prior to that, ice that had melted crept onto the galley floor, getting under the floor veneer, which is now warped.
Looking for ideas on fixing and/or replacing this, as I'm assuming we'd need the veneer as well as the wood below it replaced.  We're in South Florida. We could always cover it with a rug but that doesn't fix the underlying problem...
Thanks in advance.
-Rob
(11-04-2021, 11:11 AM)robh19 Wrote: Hi, on our well maintained 98 3100 we recently had an issue where the AC unit under the berth froze up.  We had the unit replaced but prior to that, ice that had melted crept onto the galley floor, getting under the floor veneer, which is now warped.
Thanks in advance.
-Rob
This teak & holly material is available in plywood at verious thickness. I'm not  sure where to get it in your area but you might start by talking to local boat yards. This stuff is not cheap.
When you get it you want to rip the ols and cut and fit the new.  You will need a basic knolage of wood working and if not ask a friend that does for some help.  The stuff I think is guled down and will take some effort to get up.
Good luck
Al : 3100 open Cummins.
  3500 Open deck lift piston drmiagi11 2 638 09-03-2026, 04:05 PM
  2001 3500 open, diesel exhaust flanges? North Star 4 1,462 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,085 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 2,765 12-02-2025, 02:13 PM
Last Post: E-MAN
  [Tiara Open] 2006 Tiara 42 Open Powered With QSM 11 675 hp - Thoughts ? DoctorM 5 3,971 10-20-2025, 09:05 AM
Last Post: DoctorM
98 3100 Open Flooring issue00
