Water tank level sensors
2006 3600 Sovran. The tank watch system shows full and empty lights at the same time for the water tank. I wanted to look at the sensors but I’m not sure how they come out. There’s plastic with a seal around it that goes into the tank. Do you pry the plastic out or the seal that goes into the tank? I have attached a photo.
(08-14-2025, 06:39 AM)Final Pursuit Wrote: 2006 3600 Sovran. The tank watch system shows full and empty lights at the same time for the water tank. I wanted to look at the sensors but I’m not sure how they come out. There’s plastic with a seal around it that goes into the tank. Do you pry the plastic out or the seal that goes into the tank? I have attached a photo.
I don’t see any pictures?
Sorry- I could not get picture to post. However I did find the sensors could be prayed out of the surrounding rubber ring, then remove the ring in order to allow removal of sensor.
(09-17-2025, 06:35 AM)Final Pursuit Wrote: Sorry- I could not get picture to post. However I did find the sensors could be prayed out of the surrounding rubber ring, then remove the ring in order to allow removal of sensor.
Did you ever get the sensors to read correctly? If so, what was the fix?
The sensors are available from Raritan. I ordered one thru Marine Parts Source. They pry out of the rubber grommet,then you have to remove the grommet in order to remove the sensor. The magnet at the end can be moved to test functionality.
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 612 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,389 05-26-2026, 07:27 AM
Last Post: frank.koetter
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,039 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,409 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,374 06-22-2025, 02:18 PM
Water tank level sensors00
