Rear transmission seal
Does anyone have any info, or a link to send me to, for replacing the rear seal? I have a 3100 open with 454 crusaders. This is the farthest back seal on the trans. Just before the shaft. I'm spraying trans fluid when under power.
Be sure it's the rear seal that's leaking. The O rings on the shift linkage shaft often fail and you think it's the rear seal. The O ring replacement is a one hour easy job.
Capt. george
Where is this located?
(01-31-2017, 02:04 PM)Gina Bella Wrote: Where is this located?
On the side of the transmission where the shift cable connects.
Capt. George
Thanks George. I'll look at that. Hopefully that's it. If it isn't and it is the seal, do you or anyone else have info on how to?
  [Tiara Coronet] ZF Transmission Noise Ceili 4 1,630 10-05-2025, 07:55 PM
  Differences in Port and Starboard ZF Transmission pressures and temperatures rmsullivan1@gmail.com 3 3,123 12-19-2024, 08:43 AM
Last Post: rmsullivan1@gmail.com
  [Tiara Open] 2006 Tiara 42 Open Transmission Kphillips 1 2,110 07-12-2022, 09:00 PM
  [Tiara Open] replace oil/transmission cooler waycamp 4 4,420 01-05-2022, 05:04 PM
Last Post: Joeboch348
  98 Crusader 454 Port transmission robh19 5 6,400 11-26-2020, 11:21 AM
Last Post: robh19
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
