HI everyone from Italy,
i'm owner of a beautifull Tiara 4200 (2006).
Today i realized that the windscreen washers doesn't work...
Do you have any suggestions?
Do you know where is located on board the water pump for them?
In the morning they worked, in the afternoon ko...
Author's Statistic:
Threads: 14
Likes Given: 1
Home Port: Kings Park, NY
Threads: 14
Likes Given: 1
Not sure how the washers work on a 2006 42 Open but the ones on my 2003 38 Open utilize the house fresh water pumps to supply the pressure/water.. The washers are energized via a solenoid. The solenoid on my boat is located on the starboard forward engine room bulkhead... It's also go a shut off value.. If your domestic water works then I would suspect the solenoid... M2C
