08-09-2019, 04:37 PM
Hello,
I would like to run a wire from an auxiliary switch on the helm to the engine hold to operate a relay for a bait tank pump. I have a 2002 2900 Open. I have tried to run 14GA marine romex through the same opening as the shift cables, but I can't reach the engine hold. The only thing I have not tried yet is to remove the switch panel in the cabin to see if I can gain access. Is there another way to access that pathway so I can feed wire? Other suggestions?
Thanks,
HBTiara
Thanks,
HBTiara
