Tiara Open Generator
Hi. I have a 2000 3100 Open with a 7.0 gas Westerbeke generator. I cannot keep it running and my mechanic tells me the issue is the choke solenoid keeps sticking because of corrosion. I've replaced 2. It ran fine last weekend and now it turns over and will not start. Has anyone has the same issue and any solution or ideas would be appreciated.
(08-29-2020, 02:34 PM)Cape31 Wrote: Hi. I have a 2000 3100 Open with a 7.0 gas Westerbeke generator. I cannot keep it running and my mechanic tells me the issue is the choke solenoid keeps sticking because of corrosion. I've replaced 2. It ran fine last weekend and now it turns over and will not start. Has anyone has the same issue and any solution or ideas would be appreciated.
Always look where you last did something.
 Is the choke stuck on or off or even working ?  Try operating it by hand.
Capt. George
I’m dealing with a similar issue with mine, after getting it to keep running by putting a new high temp switch on know it is having a problem starting. I took off the spark arrester and watched the choke as I tried to start the motor. The choke moved to about 25% closed and would not start, held the choke closed by hand and fired right up. Took the choke solenoid off and cleaned it up, bench tested and worked great, reinstalled and still only got about 25% choke, so I ordered a new one and it should be in this week. Maybe you are having a similar issue.
  C44 generator access for service Herbieville 0 544 10-06-2025, 06:16 AM
Last Post: Herbieville
  [Tiara Open] Generator removal maddie 7 7,317 05-07-2025, 09:10 AM
Last Post: Hot Shot
  [Tiara Open] generator fuel pick up greenaub 1 1,083 06-16-2024, 06:14 PM
Last Post: HIGH SPIRTED
  [Tiara Open] What Size Portable Generator to run my A/C, microwave, lights off shore Showtime 3 2,018 03-30-2024, 02:01 PM
  Decision time-Generator vs No Generation-need help Chesfisherman1 9 7,209 04-05-2021, 04:39 PM
Last Post: Chesfisherman1
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
