1994 3100 Open Keel Question
Hello, I have a new to me 1994 3100 Open. I pulled it out and noticed this notched area of the keel that looks like a large transducer. The normal transducer/fairing housing is located near it but I'm curious to see if anyone knows what the heck this is?
Wow - can't say I have ever seen one of those.
I have a '95 3100 Open & don't have that detail on my keel.  Near you in Mastic Beach if you have other questions.
I have a (new to me) 94 3100 open.  Prior owner created a drain plug in that vicinity - something he had done to other boats he owned - because he says that is where the water pooled.  Was not easy to see because it was forward of the forward bilge pump.  The plug from the underside did not look like your photo, but wondering if someone did something similar on your vessel?    I have since removed and glassed over his plug (and easily get water out with a shop vac during winter lay-up).
I have a (new to me) 94 3100 open.  Prior owner created a drain plug in that vicinity - something he had done to other boats he owned - because he says that is where the water pooled.  Was not easy to see because it was forward of the forward bilge pump.  The plug from the underside does not look like your photo, but wondering if someone did something similar on your vessel?    I have since removed and glassed over his plug (and easily get water out with a shop vac during winter lay-up).
new to me: 1994 Tiara 3100 Open 454 Crusaders
Strange. Wild guess but maybe the keel was modified with a removable section to sit on a trailer? Maybe to accommodate the axle or cross member?
Possible previous damage and a poor repair?
(09-17-2020, 10:17 AM)reeltimebrad Wrote: Possible previous damage and a poor repair?
No. It actually looks like a transducer housing. It has the shape of a fairing block but I've never seen something like that
How about a keel cooler for a generator? Can you access the inside of the hull in that area to see if there are hoses for a cooler or wires for a transducer?
(09-23-2020, 07:30 AM)reeltimebrad Wrote: How about a keel cooler for a generator? Can you access the inside of the hull in that area to see if there are hoses for a cooler or wires for a transducer?
Hmmm. I'll dig around and see what I can find
  Tiara 3800 Open - Buyer's Guide AtlasRearden 14 5,634 1 hour ago
Last Post: AtlasRearden
  2010 3600 Open Swim Platform bandnew 5 3,380 12-22-2023, 08:36 PM
Last Post: bandnew
  4200 Open with 660 Cummins range? Stripedo 3 2,863 12-19-2023, 12:19 PM
Last Post: Hifirush
  3100 open props bdastu21 2 2,220 11-29-2023, 03:26 PM
  [Tiara Open] 3600 Open rskdir@yahoo.com 7 6,560 11-22-2023, 10:06 AM
Last Post: MC1600
1994 3100 Open Keel Question00
