spark plug change
Replacing the plugs on my Crusader 6.0 Captain's choice.  (2006 Tiara 2900 Open). They have a little over 300 hours but are the original 2006 factory installed.  Wise to replace due to age?
Captain Pete
Yes I bet you see a better performance out of both engines
My Crusader engines have 550 hours with what appeared to be original plugs. I replaced them a week ago. Did not notice any change in performance.
preventative maintenance is worth every dollar spent your engines will thank you with 550 hrs. on them
(03-27-2015, 04:06 PM)justrollin Wrote: preventative maintenance is worth every dollar spent your engines will thank you with 550 hrs. on them
My Tiara 2005 2900 has 550 hours of salt water use when I bought it last month. First thing that I did was replace the elbows and once off I saw fingernail sized pieces of rust in the exit passages. As you may know if a riser rusts through it can let raw water into the cylinders and wreck the engine.
Small price to pay for risers compaired to having to replace motors because of water intrusion. Typically they last four to seven years in salt water depending on use.
  Power issue livewell and oil change pump smagistro 1 880 04-22-2025, 06:07 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 5 2,569 08-19-2024, 07:22 PM
  oil change system honest mark 6 8,848 01-20-2023, 07:32 AM
Last Post: MC1600
  44 Coupe - change to different anchor? kysloc4 3 3,852 12-03-2022, 10:40 AM
  Electric Grill Plug GeoDoc 3 2,842 02-14-2022, 09:23 AM
Last Post: GeoDoc
