07-15-2023, 08:18 PM
I wanted to replace several seals/guards on my 88 3100 Open
Windshield was leaking, got with Greg at Tiara got replacement flat and L gasket, did not get enough flat and screwed up the L, ordered more flat and L gasket. The second L gasket was different and fit much better. My final touch is to put a tiny bead of 20 minute caulk on the bottom corner seal seams and let it harden before closing. Light spraying got no leak but direct hard spray leaked a little.
I also cleaned the corner drains as well with a small brush.
I wanted to replace the seat seals and hatch edge guards, no luck with Tiara, got with Uni-Grip and Allyssa and got white guards for the hatches and black for the seats. The white (Part SD-1435 WT) worked awesome. The black was not what I was shooting for and another seal I got would not work for the seats. I just used the black (Part SD-1435) on the seats till I get back with a better sample to Uni-Grip. Allyssa was awesome, she looked at what I wanted, gave me samples to check the fit, then I ordered over the phone, $140 and I picked it up on my way to Lake Erie, they can ship also.
See attached picts, hopefully they attached, the way to put picts on this thread thing is funky
