End of Season Oil Change
Question, our boat has Cummins 6BTA engines.  I live about a 2 hour run from my storage location and am thinking about changing the fluids at the dock then running the boat to storage.  Any idea if running a couple hours with new oil then storing the boat over winter will have any negative effects vs changing the oil just before storage so there is next to no time running with new oil??
Thanks for any input.
Kent
Kent
1999 Tiara 35 Open, Cummins
(10-04-2015, 07:04 AM)torchlake99 Wrote: Question, our boat has Cummins 6BTA engines.  I live about a 2 hour run from my storage location and am thinking about changing the fluids at the dock then running the boat to storage.  Any idea if running a couple hours with new oil then storing the boat over winter will have any negative effects vs changing the oil just before storage so there is next to no time running with new oil??
Kent
No real appreciable difference except for the 2 hour run will get the oil fully warmed and all particles will be suspended.  a lot more than warming it up at the dock.  just leave an hour early and do it at the storage location.  Big Grin
Kent
One of the main reasons to change the oil prior to storage with diesel motors is to keep the sulfur levels  in the oil down over the storage period so they do not attack the engine seals.  I would not worry about a 2 hour run, the oil may turn color with a 2 hour run but will still be clean and relatively sulfur free. You could try to do it after your run to the storage facility but it would likely be too hot for a few hours.
Thanks!  Narrow window when they pick up the boat so will change before .  Two hour run should not should not be a problem.
Kent
I had the same conversation last week with a Cat mechanic with regard to by boat (Cat C12's).  He said the hour or 2 of run time wasn't an issue...
  Power issue livewell and oil change pump smagistro 1 898 04-22-2025, 06:07 AM
  oil change system honest mark 6 8,875 01-20-2023, 07:32 AM
Last Post: MC1600
  44 Coupe - change to different anchor? kysloc4 3 3,884 12-03-2022, 10:40 AM
  Transmission Oil Change Russf 2 5,387 02-25-2017, 10:58 AM
Last Post: Russf
  spark plug change pwilbur 5 7,002 03-28-2015, 03:26 PM
Last Post: justrollin
