probably going to Hell for this, but where is the switch to the pump out?
#11
woo woo!! I got it to pump. For the record, I have a 2006 Tiara Sovran 3600. it is configured the following way...There is no 'y' valve, rather the pump out is on the port bow, the waste overboard is in the starboard aft. So turn on the pump out switch in the dc breaker board under the steps. Now go back to the trunk and open it. Crawl in and in the rear, starboard side is a tru hull with a ball valve on it. As you can see, there are some wires on it. I thought this was a relay, it is actually the switch. Open the valve, be careful to open it slowly and you will feel the pump turn on, I pulled it all the way, and actually was 'past' the switch. So just pull the lever and you may have to jiggle it a little. Now how long you let it run, I am still not sure. But this is a vacum pump, not one of those grinder pumps. so you dont have to worry about running it dry. I guess you could have someone in the cabin moniter the guage for the tank level. (but of course that would have to work as well!!! next project!!)
that's it!!!
#12
Re: Vacuflush Discharge pumps - You will know when the tank is empty when you see and hear bubbles coming from the underwater discharge. You can't miss it. Good thing they added an on and off switch to the thru hull since operating the pump with the thru hull closed implodes the duck bills in the pump. I just replaced mine on a 2001 3500 Express. The duck bills were trashed impressively. One imploded into itself the other exploded impressively out such that you would never guess it was ever a duck bill. These are impressive pumps, very robust, unlike the less expensive Jabsco's you get to replace every two to ten years or so.
  39 Sovran VacuFlush Pump Access Euphoria38 4 2,002 12-09-2025, 09:41 AM
Last Post: Euphoria38
  2900 open - a/c water pump not running North000 2 1,269 06-22-2025, 02:18 PM
  [Tiara Open] Shower sump pump lakesidevu 2 1,574 05-26-2025, 08:29 AM
Last Post: TenBayFive
  A/C raw water pump runs very hot Joeboch348 3 2,125 05-20-2024, 10:10 AM
Last Post: Sapphire
  41 Open AC water pump vapor lock esf 3 2,006 08-07-2023, 04:07 PM
Last Post: esf
probably going to Hell for this, but where is the switch to the pump out?00
